banshee372
    montreal
    94 banshee 372
banshee372's Achievements
  1. thanks for the help guys. i will try it tonight
  2. i just replaced my spark plugs, running 40:1 oil to fuel ration. the right side cylinder only sparks at around 1\4 throttle. is there a problem with my coil? do i need to pull back plug wires and reconnect plugs to wires? if so how do i do it? i went to stealership and they want 160$ for new coil and wires.
  3. im from montreal, canada. i need a nice set of aftermarket front shocks my rear axle is getting worn where the sprocket hub sits so there is play. needs replacing both the axle and hub also need rear brake master cylinder. thanks in advance
