SouthernBanshee
Everything posted by SouthernBanshee
  1. just use some silver tape...works for me
  2. now there is a lot of carbon in the exhaust port. After clean it i only need some sand paper to polish it, isnt it??
  3. i use Motul 800 and its great, but i dont see anything wrong about yamalube
  4. great!!! i've got job to do!!!
  5. thank you Scott, ive been told that exhaust port should be like mirror finished but the intake port not... later
  6. i mean just polish, not porting... will this help that much???
  7. will this make a difference????
  8. 1st - V-Force reeds 2nd- Noss Head
  9. if you dont want to modify your stock stator plate for free, get the ricky stator's. Its the same but its not shiny like the pro design
  10. i modified it myself and its pretty easy but you need some tools... try this post good luck
  11. banchetta, have you tried PT high revs??? what do you think about them??im very happy with them but sometimes i can fell a lack of low power. I guess i will have that solved with a .030 milled head, the +4 advance and the lightened flywheel... coming soon!!!
  12. great!! so i will take .030!!!
  13. engine is stock. Other mods: PTR Hi-Rev pipes, ported reed cages with boyesen power reeds and pro-flow air filter. ive just modified the stator plate +4 and will get the flywheel lightened... thanx
  14. i used a metric caliper. i dont know if it is the exact mesure but its very aproximate... thanx boonman...i already took the flywheel and the stator plate to mod.
  15. i want to get my stock head milled .030 but i need to know which is the size of the step between the head seat and the dome. My stock head is 1.3 mm more or less. Is That the stock size or has been milled before???? my compression is 126 and 128. Sea level thanx
  16. thanx Nicolas, that will help a lot!!
  17. hi people, i wonder if any of you have pics of a lightened flywheel and which is the size of the flywheel nut (mm). later
  18. ok, i have NGK BR8ES right now so i will get a new pair...
  19. which spark plug is best, NGK BR8ES or some Splitfire??? Thanx
  20. will the rfi wire give me a poor spark???
  21. hi i have to change my spark plug wires and the stealershop offers me some Accel Spark Plug Wire. They have common 8.8 mm wires and 8.8 mm RFI Suppression. He told me that the common wire is for racing cars but the other is used for engines with special ignition components. So, which one for the banshee??? will the common wires mess with the cdi or stock ignition??? Thanx
  22. is your clutch basket ok?? sometimes the stock basket is a real headache...
