FORMULASPEED
Everything posted by FORMULASPEED
  1. The local new has been talkin about this, same with the radio stations. He said he new how to do that from driving on his moms lap an video games. His max speed was 15 bouncing off snow banks an parked cars. Yamaha should pic this kid up before someone else does
  2. Ah. Wiseco makes a kit for the long rod an the stroker wich you do not need head or case mods, but uses there special gaskets. Your proof is at wiseco.com An the 795 goes up to a 66mm bore I have 65.5 If you want bigger WSM offers bigger even into the big bores.
  3. Heres a couple of things >link >link The monoblock kit on this page they go on ebay for $1300 buy it now or give Jim from passion a call here is his site >Passion
  4. Wheres everyone goin today?
  5. Its the Chyn Chyn thats more flatter on the width (maybe that pic is screwy). Use Kold Kutters an not nock offs. Aligning the SLIT left to right is forward bite and aligning slit vertical is side bite. Side bite used on your front tires. Foward bite used in the rear tires leaving some outer rows for side bite. For circle track an recration. Snow mobile Picks an chissles will work for drag.
  6. That was just coatings. Today I bought the new dirt wheels theres an add for powder coating. I seen it was in Tecumseh Mi So I called this guy, he wants $250 which includes blasting an prep for 1 stage coat. His 2 stage coat such as Candy colors a lil more. Phone number is 517-403-6368 also has a web site its www.bbcoatings.com
  7. All the quotes were I live were $350.
  8. Just as it says.
  9. Cam? Fu^k! I new I forgot somethin when I swapped cases
  10. They can use your finger nails. Not to say they will but they can go that way to.
  11. Shitty I heard thats a big ass fine. Where at did it go threw?
  12. Thanks IceRacingShee for the good deal
  13. Yeah I got that graph thanks though. Ill just try every clip.
  14. Is the stutter or a burble the same thing? You say to corrrect this is a fatter needle, or possibly raise the clip to drop the needle farther in to the main. wont this cause your main to lean a lil. Im runnin mikuni 28mm flatslides with needle #s 5L1 if droppin my needles 1or 2 clips an it dont cure it should I drop it some more? or go with a fatter needle an would a fatter needle be 5L2. I still need the float height cant find out what it is. I even went to a snowmobile builder to ask an he dont even measure them
  15. There is some picked tires on ebay for $75 with Red Labels. They need reconfigured. Ice Tires
  16. My stockers didnt have the size .
  17. The cold isnt bad especialy 28. I think riding in a rain storm is worse, that shit hurts. Riding bikes in the winter around here is popular studds or rubber.
  18. Delete this. No longer for sale.
  19. I wont make it today. I still need that gasket and need to do some minor stuff. And I need to get my truck fired up. I plannin for sure tommarrow the visibility will be alot better too. I drove pass the spot an the parking lot is packed but I couldnt see out there. If you come down today BIZ Ill buy that gasket off you I live just past the draggin spot. If so shoot me a PM an Ill give you my phone #
  20. Souds good but the dam bliz incased my truck engine in snow I just pulled the distributer cap an cleaned it out still no luck. H&R block called they got my check an Im stuck. But Im goin to steal the ol ladys car get my check an stopp by my buds house if he's home to get the gasket. Ill update in a lil bit.
  21. Round house.
  22. I dont feel tardy I need a clutch cover gasket. Its going to take me longer to go get it than put it in, cause of this blizzard. But I Ill make it. Bogart If you have another stator put it in. Also check the spark plug caps to the coil wires they get coroaded.
  23. Also interested on the -Neg
  24. Is that out of a crotch rocket Dunedemon?
