q8bizkit78
Everything posted by q8bizkit78
  1. u sound that you have an air leak or somthing wrong with ur reeds
  2. guys i have a race this week end i need the best set up of gearing for the race im set up as 15/41
  3. 4mm strocker dragport cpi inframe vitos 404 big bore manifold with out boost botle 35mm carbs im on sea level so could you guys help me out i have a race next weekend and i dont have time to try out diffrant size of jetting
  4. im wondring can the dmc pie handel the 404kit with 4mm strocker
  5. i have been ruinnig spacers for 2 years now they are just fine took them of my shee put them on my yfz and still great but the thing is get the plastic easy fit
  6. what do you guys think of the set is it worth it
  7. im taking my shee for a dyno test this week so i was wondring should i take my gearing back to stock im running 15/40 at the moment because i want a correct reading
  8. first of all r u from UAE if you are please pm me
  9. around 200$
  10. run 41-15 gearing thats it
  11. i will post some pics soon
  12. b4 installing the toomey rad my pistons get overheated and over sized then gets stuck it happend twice but after unstalling it my temp after each race get max 150-160
  13. PC i like it as an overall pipe
  14. i start at 3rd and somtimes 4th
  15. has anyone raced the trx-450 yet
  16. http://www.gpt.it/power_rpm%20eng.htm
  17. about the tep it gives both C&F plus i will install it soon so ill post some pics and regarding the specs ill post them today for you guys guess where did i find this product in a gokart store
  18. guy who doesnt want 2 read his rpm and temp i just installed this product http://www.gpt.it/POWER%20RPM.htm
  19. its easy go for the raptor rear tires they are amaizing my friend uses them for his 7mm strocker and t-rex clynders
  20. guys im running 4mm strocker with 35mm carb 15/41 and guess what you guys should try out i have a set of cpi , thunder and dmc with the 4mm strocker the dmc is a killer you guys cant bleave the result we drag race 1/8 of mile and for such distance the big pipes dont work that well and one more thing i have another set of carbs 28 flatside they suck when it comes to the 35 who knows i might get the 36
  21. does anyone knows how to covert the sizes of the main jets from mikuni to kehin when i was useing the stock carbs i used to run 380 main i changed to kehin carb so i used 155 main
  22. i agree with mr mooney
  23. never use a biger carb on a stock port second you sound to lean first of all check of you have a leak in the intake second check your crank seal and you gaskets and one more thing the bigger the boost is the bigger jets that you would need btw with the jet skys but its not called boost its called equlaizer could you imagine since we installed it we changed the jets from 150 to 240 plus if you keep on running it the way it is you pistons will get stock from the front side next to the pipe port
