Hi,
I am fitting 30 mm mikini round slides, and the left float bowl seems to want to contact the clutch actuation lever. The application is RZ, but as the motors are so similar I thought maybe I could find a little help here? What is the usual answer, spacers, different boots, different reed cages or manifolds? It has been suggested that I grind and weld the float bowl, but that doesnt sound like the best answer. any ideas?
Thanks in advance
Robley
you can bend the lever down a little and loosen the carb then tilt it up some. If that dont work, buy some 1/2" reed spacers off of ebay for it.
you can buy billet intakes that will get rid of the boost bottle/corssover tube and also lifts the carb over the arm.
Yep get a boss racing intake. They move the carbs up and back so they dont hit on the clutch arm. They make them for 28-30mm 33-35mm carbs. PM Dajogejr about getting one. He can hook you up.
Here is my boss intake with PWK 33's.
I have the Boss Racing intake for 33-35mm carbs. I got it from in2glamis (Inland Atv) for 100 bucks. I dont know if they sell them for that price any more. I have seen / herd of some people buying them from a certian seller for 60 bucks. I dont know who the ebay seller is.
White Knuckel Racing makes a similar intake only it has cross hairs in the intake thoat. It sells for 135
http://www.whiteknuckleracing.com/contents/en-us/d3.html
Just make sure you select the right size. They have 3 different ones.
I would PM Dajogejr first. He can get boss racing products at about rock bottom prices. He is a good guy to deal with, and very helpfull on the boards. Deffinatly not a fly by night guy.
Here is boss's web page. It says 153 but I imagine dajo can do much better. After having it I would pay 153 for it if I had to though. It is a nice product and the rubber flanges can be replaced for about 10-15 buck each.
http://www.bossatvracing.com/index.php?mai...eemrukklt3svdl4
josh
