I keep getting water in my stator side cover anybody got any ideas on how to stop this. I put silicon on both sides of the rubber seal. Im not sure if it gets in while riding or washing. Also I noticed 2 spots on the cover that look like a doule (sp) pin goes to hold the cover and case it the same spot. Are there supposed to be pins there like the clutch side has or not?
Make sure it's not getting in around the wires going to the stator. There is a rubber grommet that is supposed to seal that hole. Make sure it's still in place.
That is where it was gettin in on mine. I also drilled a couple small holes in the bottom of the stator cover so it can drain out.
I thought about drilling holes but was worried it would get in there. Did it work.
yes, the stock cover has a couple of locating pins if i remember correctly.
also there is a small rubber half moon plug that goes in front of the section
that seperates the stator area from the sprocket.
