I need help getting started with jetting
my elevation is 918 feet above sea level
my mods
Trinity mx port and polish
head shaved
wiseco prolite pistons .030'' over
toomey t-5 pipes
+4 timing
k&n pod filters
stock carbs with tors removal
stock reed cages
Who built the engine for you? Port jobs can be a little tricky to jet depending on who did the work. I would say your probably around a 320-340 main on stock carbs with either 27.5 pilots or 30 pilots. I know its not much help, but maybe someone else will chime in. Your builder would be able to give you the most accurate info though.
Call the builder and they should be able to tell you the range of juts you should be using. When Kevin Herr did mine he sent me the jet with the jugz :notworthy: . I installed it and it ran perfect. The builders should be able to help you out.
