klotz_racr Posted July 17, 2008 Report Posted July 17, 2008 Is there anywhere that i can order a complete kit with the rods, pistons and everything? or do i have to order everything seperate? What exactly do i need besides the Piston kit and the rods? thanks Quote
blowit Posted July 17, 2008 Report Posted July 17, 2008 Is there anywhere that i can order a complete kit with the rods, pistons and everything? or do i have to order everything seperate? What exactly do i need besides the Piston kit and the rods? thanks +4mm stroker long rod crank, 795 pistons, modded head for the stroke, a smile. stroker porting is recommended but engine will run without, just not very good. Brandon Quote
atvfreestylekid Posted July 17, 2008 Report Posted July 17, 2008 Is there anywhere that i can order a complete kit with the rods, pistons and everything? or do i have to order everything seperate? What exactly do i need besides the Piston kit and the rods? thanks You can get everything at vitosperformance.com or farmandsandtoys.com All you will NEED are the crank and wiseco 795 pistons if it's a standard stroke long-rod crank. But it needs to be ported. does not have to have it. Will run alot better with it. My 4-mill with the spacer set-up does not perform the way it should. But I could not afford a stroker set-up and porting at the same time. So porting will have to wait until the next top-end rebuild. Quote
klotz_racr Posted July 18, 2008 Author Report Posted July 18, 2008 ok, thanks alot guys, that really helped! i think im going to get it from FAST, because it seems like they really support the site. Quote
