Just redid the top end and got my 35's synced really good but I have took it for a ride 6 times and twice it bogged down a little when going from 1st to 2nd gear any setting I am over looking?
Thanks
Tony
Did you break it in? If you didn't yet then you should expect it until the engine is fully broken in. Once it is broken in then you will have to adjust your jets to your compression. You my have a good spark plug reading but if it bogs then you should probably go down a couple sizes on the main jet. I had that problem too but once I boosted the compression a little after a rebuild it ran perfectly! Keep in mind when it is not broken in it will have lower compression than when it is broken in. I did the readings with a compression gauge when I did a rebuild.
