Nology Coil with Nology Hotwires. Banshee started much easier with it on. I also run B8ES non resistor plugs.
Jeff at fast has the best price on the kit. You will need to make a mounting bracket, but that is pretty easy. Just use a small pice of angle Iron.
The nice thing about the coil is you can chage plug wires just like on a car. You could also get a MSD Superconductor kit if you didnt want to run the expensive hot wires.
Make your own custom wires for the nology coil too.
http://store.summitracing.com/partdetail.a...mp;autoview=sku
http://www.farmandsandtoys.com/partdetail.asp?partid=46
i just installed a new dynatek ignition system. the coil seems to work good. the plug wires do not come with ends so i installed ngk 5k resistor ends and run a b series plug not a br. it starts a lot better, i was using RZ electronics and i previously remounted the coil, and the dyna slid right in no probs (not sure if its a direct bolt on in the factory spot)
I'm gonna try a nology. Heard great things about them.
PVL on a drag bike would be pretty cool.
Although I've seen some hard runnin mothers with just the stock coil... :confused:
Word. :thumbsup:
