Well if they were done right they'll probably have a powerjet on them.
the holes in the splash bowls have been drilled out large, and vintures on the needle slide have been ground down, i cant get the bike to clean up down low...... it runs good in the power band, down low it is rich and smoky... thanks
All you will have to have in powerjets & your main jet drilled out but when you get the powerjets make sure you get the adjustable kind not the kind you have to put the jets in.
