I just had my engine rebuilt by Jim at Passion.. I set it back in the frame hooked everything up and when I start it, It only fires on the left cylinder. I have switched the plug wires, switched the coil out, and it still only fires on the left side. When I pull the plugs and kick it over both plugs seem to be firing. I am lost, any ideas guys?
Im having the same problem, jim built my motor about 6 months ago and i think i have a bad crank seal.
do you have oil and shit spitting out of the left cylinder..
Where at out of the cylinder? It has run for maybe a total of 2 minutes so far.. Just long enough for me to start it and realize that it is only running on one cylinder and shut it off. I am sofa king confused on what it could be. The only thing that comes to mind is that my stator isn't putting out enough juice to provide strong enough spark for both cylinders.
I got it fixed! I just had to evict a family of mice that had taken refuge in my pipe. I couldnt even blow all the shit out with an air compressor because they had it packed so tight. I ended up pouring some gas in it an dropping a match inside. PROBLEM SOLVED!
Check for mice, lol.
Apparently that works.
Hahahaha thats awesome..
I dont think thats my problem considering i was riding my bike that weekend and it ran awesome all weekend with no problems..
Im glad that you got your problem worked out..Im sure you will be very happy with the work that jim did, my shee has ALOT of power for alittle mx port
