need to know where to get case sealer, and what to get. yama bond 4 dosent look to be avaliable anymore what the heck do you use now. When applying whats the best method, do you all let it set or do you put a thin coat on both halfs and put it straigh back together and torc to spec. It seams odd not to have a gasket for the case but i guess its a clearence issue for bearings on the shee. odd design but it works. any links would be appceated
Get some treebond 1215 or 1211, I our country Yamaha sells the treebond 1115 with a partnumber, so you can get it from Yamaha. I apply only a thin layer on one half, and just put the cases together.
Edited by 2strokespirit
I used Permatex MotoSeal from Napa with no probs, like 2stroke said just get it evenly on one side and carefully set the other side on it...
come on 2strokespirit i wanna see some pictutres of what it looks like to ride in south africa!!!
Its typical Africa... We ride were ever we can, the Cross Country Races are very nice to ride, don't really have good photos of certain spots..
I use threebond 1194 thats what replaced yamabond 4. Most dealers have it in stock.
exactly....the three bond 1194 is what to use. if you find some 1104 at some shop, that will work too. its just an older version of the 1194. 1194 now replaced the 1104. the formula was changed a little.
Edited by mopar1rules
