awaitedshee Posted June 21, 2008 Report Posted June 21, 2008 ok fellas i got the shee runnin right and it just flat out screams it has nice compression now and rebuilding the carb and new plugs and some 110 race fuel did the trick :biggrin: its wicked bad very impressed with kevins port work. but anyways i was riding last night and all the sudden shee wont shift anymore! i let it cool down and i can run thru 1st to 3rd gear but then 4th is a complete bitch to get into and so are 5th and 6th its like ill hit neutral and have to keep tryin to shift like ill feel no click at all.....what the hell happened did i bend or break somethin? the oil level was half full. did i smoke the clutch or what? Quote
huskyohilux Posted June 21, 2008 Report Posted June 21, 2008 ok fellas i got the shee runnin right and it just flat out screams it has nice compression now and rebuilding the carb and new plugs and some 110 race fuel did the trick :biggrin: its wicked bad very impressed with kevins port work. but anyways i was riding last night and all the sudden shee wont shift anymore! i let it cool down and i can run thru 1st to 3rd gear but then 4th is a complete bitch to get into and so are 5th and 6th its like ill hit neutral and have to keep tryin to shift like ill feel no click at all.....what the hell happened did i bend or break somethin? the oil level was half full. did i smoke the clutch or what? The clutch should have nothing to do with it you should be able to slip in different gears even without using it, I wouldn Quote
Toybreaker Posted June 21, 2008 Report Posted June 21, 2008 If you were lucky you screwed up the shifter shaft or the pin that centers the shifter shaft under the clutch cover... either way the clutch cover needs to come off. If you are unlucky you are splitting the cases and replacing some gears. Take it apart and let us know what went wrong. Quote
awaitedshee Posted June 21, 2008 Author Report Posted June 21, 2008 yea the gear box worked fine just after some good hard riding it went to hell and 6th gear was pullin like a bat out of hell its like i hit nitrous goin into 6th it is amazing or was i should say. but i dont even know where to start so any help would be great. Quote
Toybreaker Posted June 22, 2008 Report Posted June 22, 2008 Pull the engine. Take the engine apart, all the way apart. split the case and look at the transmission. On N2O shifting into 6th gear. Your trans has some broken teeth. Get an aftermarket set of gears or you will be very good at splitting your cases. Quote
