Ive been having a cooling problem with this new Banshee I picked up. Even with jetting way rich, engine ice, inline cooler. My CRJ temp gauge still shoots up to 180....fast. Even at speed it wont go below 180-190. When you let it idle for a second it jumps to over 200. Ive check all I can think of. Even a new O-ring kit for my cool head. The fins on the impeller are in good shape, Impeller spins freely. I did notice if I put my thump and press the top of the impeller with a little force the impeller does not move. Im not exactly sure how its designed I just got into banshees. So should it still move if I am pressing my thumb on it?
Im not sure, but if you have the impeller out you may as well replace it with a billet impeller. Then you kill two birds with one stone. You can check to see if the new impeller spins when you put pressure on it and you now have a billet impeller installed and dont have to worry about the plastic stock one burning itself out.
You should not be able to hold it w/your thumb. Check the plastic gear and pin that goes through the impeller shaft to to see if it is chewed up(will spin freely) You will see what I mean when you take off the plastic gear on the back side of you clutch cover.
