i am running a set of 41 mikuni carbs from K&T.i found that i can't get the slides to go up the whole way.if i adjust the tops of the carbs i can make them come open but then they won't go shout the whole way.the cable i am using is for these carbs.its a mp 07-0868 by motion pro.i am also running a stock thumb throttle.anybody know what i need to do?
Yep.
One of two things. Get an aftermarket thumb throttle that has more throw (Chariot makes a nice one, click on my sig) or take the top off yours, where the back of the arm hits, grind that off so it clears.
A lot of guys with stock thumb throttles have to grind the back of the throttle out for 39PWKs, I can't imagine the 41Mikunis being any different.
get an adjustable terry cable and like dave said grind on teh back side of the thumb housing so it opens more.
i think if i grind off enough to get the throttle to open the whole way i think the arm where the cable hooks to will be sticking out the housing.the slides are hanging down 3/8 of a inch.so might just invest in a aftermarket thumb throttle.thanx
Awesome. Let's figure out how to ship the Pick tires to you as well. I'd like to see you run them on a track there.
1 pick pulled through, what guys normally do is dismount the tire, patch the inside with a piece of roofing shingle...then put it back together. Obviously, they are tubed tires.
Let me know what you want to do....
