xXBlessedWithDeathXx Posted June 9, 2008 Report Posted June 9, 2008 I was working on routing the cable for the thumb throttle that i just installed and cant stand and i wanted to take the side tank shrouds off to see better and now i have a screw stuck in the tank towards the back of the tank closest to the seat. i`m guessing the threads are spinning inside the tank. i didnt put much time into it to try to get it out but is there an easy way of doing this or do i just buy a new tank before i have to take it off. Quote
okbeast Posted June 9, 2008 Report Posted June 9, 2008 Just cut the bolt head off. Your plastic will still grab onto the rest of it that's sticking out. Quote
xXBlessedWithDeathXx Posted June 9, 2008 Author Report Posted June 9, 2008 Just cut the bolt head off. Your plastic will still grab onto the rest of it that's sticking out. Shit. good one man. that was just to easy. Quote
locogato11283 Posted June 10, 2008 Report Posted June 10, 2008 yea, you can cut it off and probably thread a nut on there.. Quote
ItzaBansheeBitch Posted June 10, 2008 Report Posted June 10, 2008 Thats a fuckn shitty way to fix that!!! Take a pry bar and a cordless drill. Chuck up a 10mm in the drill, spin the bolt and pry between the tank and plastic. This will make the plastic warm and the threads will come out. Clean up the hole with a screwdriver (Leave some stuff inside for reinstallation), Change the bolt in the threads. HEAT the threads (is actually a socket nut)and mash back in the hole, Remove fill with Jb weld and reinsert. When done use a new bolt and dont be HE-MAN its fuggn plastic, SOFT HANDS!!! Quote
pabansheematt Posted June 10, 2008 Report Posted June 10, 2008 I was working on routing the cable for the thumb throttle that i just installed and cant stand and i wanted to take the side tank shrouds off to see better and now i have a screw stuck in the tank towards the back of the tank closest to the seat. i`m guessing the threads are spinning inside the tank. i didnt put much time into it to try to get it out but is there an easy way of doing this or do i just buy a new tank before i have to take it off. duct tape or a bungee cord. all is well. Quote
monster_energy06 Posted June 10, 2008 Report Posted June 10, 2008 mine the same also. i just cut the head off like said above. works awsome one less bolt to take off lol Quote
Blackharp Posted June 10, 2008 Report Posted June 10, 2008 Try the Holyman Tech Tip, see links below. Holyman Tech: Tank Screw Repair http://www.bansheehq.com/forums/index.php?showtopic=26260 Quote
