shakenbake1285 Posted June 4, 2008 Report Posted June 4, 2008 which bolts do i need to loosen to tighten chain, i no u need to loosen the 2 on back of the swingarm. Quote
hyperlite33 Posted June 5, 2008 Report Posted June 5, 2008 which bolts do i need to loosen to tighten chain, i no u need to loosen the 2 on back of the swingarm. If you have a stock swingarm, loosen the top and bottom bolts on the carrier behind the rear disc. Then use the 2 adjuster bolts that are below and behing the carrier to tighten the chain. Quote
