bansheeman1974 Posted May 30, 2008 Report Posted May 30, 2008 hello everybody , ok this is my problem my reed broke for the second time , i have v force does anybody have a clue thanks. Quote
jbooker82 Posted May 30, 2008 Report Posted May 30, 2008 Do you have them set on Low Tension or High Tension? Low tension wont last long. Quote
monster_energy06 Posted May 30, 2008 Report Posted May 30, 2008 Do you have them set on Low Tension or High Tension? Low tension wont last long. hey sorry for high jack but how do u ajust yur reeds tension?? Quote
Animalman294 Posted May 30, 2008 Report Posted May 30, 2008 Placement in the reed cage. The directions say high or low tension when you install them and they show you how to place them.............. Quote
bansheeman1974 Posted May 31, 2008 Author Report Posted May 31, 2008 are they 2's or 3's?? 2's i never heard of that eather Quote
rubberneck Posted May 31, 2008 Report Posted May 31, 2008 Placement in the reed cage. The directions say high or low tension when you install them and they show you how to place them.............. What did I miss, I dont recall anything about this in the directions that came with my VF3's. Will have to re-read them. First I have heard of this Quote
shanYE west Posted May 31, 2008 Report Posted May 31, 2008 What did I miss, I dont recall anything about this in the directions that came with my VF3's. Will have to re-read them. First I have heard of this You can't change the tension on the 3's. Quote
rubberneck Posted May 31, 2008 Report Posted May 31, 2008 Ok, I thought I had been left out on some big secret. LOL I know i didn't see anything in the directions. Quote
jbooker82 Posted May 31, 2008 Report Posted May 31, 2008 2's i never heard of that eather When you take the reed cage out look at the metal bar that goes across the top of the reeds. It will have HIGH or LOW stamped on it. On the high setting the metal bar clamps down a little farther on the reed. Makes the reed a hair shorter so it has a higher tension. When I replaced my petals on my 2's Jeff at fast told me to make sure they are on high tension. He said they wont last on low tension. Quote
bansheeman1974 Posted June 28, 2008 Author Report Posted June 28, 2008 he is right, i just took mine apart again and yes it does have low and high , mine is on high thanks for the help. Quote
