Placement in the reed cage. The directions say high or low tension when you install them and they show you how to place them..............
What did I miss, I dont recall anything about this in the directions that came with my VF3's. Will have to re-read them. First I have heard of this
You can't change the tension on the 3's.
2's i never heard of that eather
When you take the reed cage out look at the metal bar that goes across the top of the reeds. It will have HIGH or LOW stamped on it.
On the high setting the metal bar clamps down a little farther on the reed. Makes the reed a hair shorter so it has a higher tension. When I replaced my petals on my 2's Jeff at fast told me to make sure they are on high tension. He said they wont last on low tension.
  • 4 weeks later...
