Do you see any difference between different size of front spocket on de dyno.
ex: the same bike, you just switch 16 thoots to 14 thoots, this switch effect the hp result or not????
I believe you would see more torque to the wheels but no change to the engine HP or torqeu. You will lose speed. IE, you put a 5 tooth sprocket on you would have enough power to pull a tractor but you would only go 1MPH.
you want it geared high to load the motor up so put a 16 on it. then change it back when you go riding unless you run a 16.
