OpEnUpYourEyE
    98 blue & White, Bored over, K&Ns, Reeds
OpEnUpYourEyE's Achievements
  1. I believe you would see more torque to the wheels but no change to the engine HP or torqeu. You will lose speed. IE, you put a 5 tooth sprocket on you would have enough power to pull a tractor but you would only go 1MPH.
  2. Any one know where to order an overflow bottle bracket when you get rig of the stock air box. i fount one that looked cheep and onother thet was 89.00$$.
  3. I want to go big, pluse in the long run wouldn't it be pointless to put money into the stock moter?
  4. So this 472cc , 72 mm bore Cheetah Super Cub Cylinder only for 4mm stroker crankshaft. All-new crank by Hot Rods. 115mm Long Rods with 4mm stroke and 8-ball main bearings. Trued and Welded. Does not require case modification, uses new Wiseco Long Rod pistons and special gasket kit. Can also be used in many different piston combinations, depending on personal preference. What is dune port from Jeff at FAST?
  5. I have a 98 Banshee of course. I has been bored just over stock (lost a filter at the dunes). I don
  6. Ok, I think I can figure the float thing out but just in case I can
  7. is the Tors the thing that was making it idle WAY high?
  8. I am in utah. how do you tell were the float is to ajust. I am way new to this jetting carb stuff. thanks for the reply
  9. Hi every one. I am new here and have a problem. Sorry for the long story
