arfountain Posted May 15, 2008 Report Posted May 15, 2008 When you guys replace your clutch cover gasket do any of you put any gasket maker stuff on either side or do you just trust the gasket to do it's job. I had a leak and was working on replacing it, and thought I would check with someone real quick. Thank you. Quote
LeadBoots Posted May 15, 2008 Report Posted May 15, 2008 ive used gasket maker lots and had no problems. It is just easier using a real gasket Quote
FireHead Posted May 16, 2008 Report Posted May 16, 2008 When you guys replace your clutch cover gasket do any of you put any gasket maker stuff on either side or do you just trust the gasket to do it's job. I had a leak and was working on replacing it, and thought I would check with someone real quick. Thank you. I don't use a gasket, I just Yamabond it. :geek: Quote
Leadfoot350 Posted May 16, 2008 Report Posted May 16, 2008 You pretty much always tear up the gasket when you take it off. I hate paying 13 bucks each time I take it off. I would buy 10 for 50 bucks if I could. So much money wasted on gaskets. Quote
