money mike Posted May 14, 2008 Report Posted May 14, 2008 i got a motor bored out with 66mm pistons...what size carb would i need if i were to run a single carb set up? Quote
Bansh-eman Posted May 14, 2008 Report Posted May 14, 2008 what kind of riding? any specific reason you want to do a single carb? also keep in mind you dont want to sink alot of money into a set of jugs that are 66mm becasue your not going to get much life out of them. you would be better to bu some used jugs that are closer to stock bore and port them instead Quote
Banshee0028 Posted May 14, 2008 Report Posted May 14, 2008 i got a motor bored out with 66mm pistons...what size carb would i need if i were to run a single carb set up? Depending on your mods, you can go 33, 35 or 38. I just sold a 38mm. Look around in the FS section and see what you can find. 35 might be best if you dont have alot of mods. Quote
