Blackwizard22 Posted May 10, 2008 Report Share Posted May 10, 2008 I see many people use ATF Type F in their banshees while others use 75w90 and yet again some people run straight 40 oil. What are the pros and cons to each? If your banshee already is running one type is it best to just stick with that type? Quote Link to comment Share on other sites More sharing options...
Wildcardracing Posted May 11, 2008 Report Share Posted May 11, 2008 I see many people use ATF Type F in their banshees while others use 75w90 and yet again some people run straight 40 oil. What are the pros and cons to each? If your banshee already is running one type is it best to just stick with that type? People use the Type F because it's a very light oil and causes less resistance in the trans which equals more power to the ground, it also makes your clutch hook beter. The thicker oils have stronger film strength and are actually beter for you bearings and bushings. Yamaha recommends either 10/30 or 10/40 yamalube 4R, can't remember which. Quote Link to comment Share on other sites More sharing options...
mopar1rules Posted May 11, 2008 Report Share Posted May 11, 2008 i personally am running the belray gear saver trans oil. Quote Link to comment Share on other sites More sharing options...
dirtydownunder Posted May 11, 2008 Report Share Posted May 11, 2008 i use agip full synthetic 75/90 Quote Link to comment Share on other sites More sharing options...
gregrob Posted May 11, 2008 Report Share Posted May 11, 2008 The lighter oil helps it shift easier, as well as the other benefits mentioned above. The gear oils everybody is running are too thick IMO.... Run either what the manual recommends (30wt) or a trans fluid. People run Type F because it's cheap. I'll be running Synthetic ATF, probably Dexron III in my new engine. Quote Link to comment Share on other sites More sharing options...
jonnyb Posted May 11, 2008 Report Share Posted May 11, 2008 I was told by a&s racing to use 5w30 mobile 1 syntectic. Said that it keeps it cooler and is easyier on the fibers. I'm going to try it see how it goes since they just put a new clutch in for me. Quote Link to comment Share on other sites More sharing options...
Midway USA Posted May 11, 2008 Report Share Posted May 11, 2008 I have been using Rotella T 15W40 in mine. Mostly convenience related since I run it in my mowers and my sons Chinese 110 ATV. The local Yamaha guys said any motor oil works as long as it isn't moly based in any way. Quote Link to comment Share on other sites More sharing options...
omalavet Posted May 11, 2008 Report Share Posted May 11, 2008 I see many people use ATF Type F in their banshees while others use 75w90 and yet again some people run straight 40 oil. What are the pros and cons to each? If your banshee already is running one type is it best to just stick with that type? i use flex Drive Quote Link to comment Share on other sites More sharing options...
WildShee Posted May 11, 2008 Report Share Posted May 11, 2008 I also fun Klotz Flex Drive 30 Quote Link to comment Share on other sites More sharing options...
