locogato11283 Posted May 11, 2008 Report Posted May 11, 2008 Ummm, every banshee I've ever owned has had the nuts on the sprocket side loco. thats weird. ive never even seen one on the sprocket side. so maybe it doesnt matter which side the axle goes in from.. but still, that hub should be sliding into that seal and its clearly not on those pictures. Quote
Wildcardracing Posted May 12, 2008 Report Posted May 12, 2008 but still, that hub should be sliding into that seal and its clearly not on those pictures. agreed Quote
FireHead Posted May 12, 2008 Report Posted May 12, 2008 your axle is in wrong. the axle nuts should be on the brake side.. flip that shit around and it will fit right. there should be no gap. Yeah............ that's not right. The axle nuts should be on the sprocket side. Are you sure your nuts aren't flipped around (read: twisted testicles)? :ermm: The seal race on the sprocket hub needs to slide into the carrier seal. You need to find out why that gap is there. :geek: Quote
