Wildcardracing Posted May 9, 2008 Report Posted May 9, 2008 I ran 187 deg. with my fmf's, That duration compliments a mid pipe quite well :thumbsup: Quote
BigRed350x Posted May 9, 2008 Report Posted May 9, 2008 stock port timing would be far better for a bottom end motor. The cylinders you have should come on strong in the upper mid range and build a lot of topend power with very little on bottom. I run similar port timings on my stock stroke dune motor (196 deg), it will run with most builders drag ports but I have some tricks to maintain some of the bottom end so it is still very rideable on the trails an in the dunes. Don't lie. :biggrin: Quote
Wildcardracing Posted May 10, 2008 Report Posted May 10, 2008 Don't lie. :biggrin: What you talkin bout willis????? Hey red when you gonna bring that 4mil over and play, I think you'll be quite supprised how my little stock stroke gasoline burner runs Quote
