axlracing Posted May 6, 2008 Report Posted May 6, 2008 (edited) hey here is the link to pics of my carbs this is kinda hard to explain but there is a little brass looking tube that i have on one carb but not both of them. its a little brass tube that goes into the bowl i have a pic of both carbs on has it and one is missing is it sopost to be like this thanks alot axl http://i278.photobucket.com/albums/kk97/ax...heecarbs002.jpg Edited May 6, 2008 by axlracing Quote
350BANSHEE350 Posted May 6, 2008 Report Posted May 6, 2008 thats for the choke, with that being said, you need to make sure you have the proper bowl on that carb Quote
axlracing Posted May 7, 2008 Author Report Posted May 7, 2008 thats for the choke, with that being said, you need to make sure you have the proper bowl on that carb so there is not supost to be a brass tube like that on the carb without the choke? and i just went out and looked at my bowls and they both look indentical to me except when you look in the inside onw bowl says 1-1 and the other says 1-2 thanks alot axl Quote
axlracing Posted May 7, 2008 Author Report Posted May 7, 2008 any idea what bowl goes on what carb? Quote
NitroTate Posted May 7, 2008 Report Posted May 7, 2008 I've always questioned this myself because both of my bowls have the tube and are identical... Did Yamaha do this back in 89' or do I have two of one bowl type in error??? Quote
Black&Red87 Posted May 7, 2008 Report Posted May 7, 2008 1-1 should go to the choke tube and be on the left side. If the setup is wrong it will run like crap. Quote
