thats for the choke, with that being said, you need to make sure you have the proper bowl on that carb
so there is not supost to be a brass tube like that on the carb without the choke? and i just went out and looked at my bowls and they both look indentical to me except when you look in the inside onw bowl says 1-1 and the other says 1-2 thanks alot axl
I've always questioned this myself because both of my bowls have the tube and are identical... Did Yamaha do this back in 89' or do I have two of one bowl type in error???
