Axel scratches
jamebo
I know it's an atv and it's going to get some battle scars, but does anyone know of some way to remove scratches from a stock axle? I have several very noticeable ones and tried buffing them out to no avail. ( they are dark scratches and stand out )
I was thinking of using some fine steel wool, but with the bright finish on it I'm scared that the metal underneath may be darker and wool might make things worse.
It's something I can live with, but just wondering if anyone knows a fix for this. Has anybody tried the wool?
On my 250r, i had some pretty nasty looking scratches. Instead of removing them, i covered them up. I got a hold of some really big heat shrink off ebay and pulled the wheel hubs off. put the heat shrink on and used a propane torch to shrink it down nice and tight. Start at the inner side and work your way out. Leave the shrink a little longer than you need and when you get it shrunk all the way out, trim off the excess, reinstall your hubs and you are done.
it will clean up if you take fine emory paper, put the rear up on a block, start it. let it idle in gear and let the axle spin with the emory wrapped around it.mine was all rusted and came up like new.
That sounds good too, I really appreciate the great tips guys! Where I ride at has alot of brush, stumps, and fallen limbs through the trails which can wreak havoc on an axel finish!
