Yep...offset the cheap cylinders with 600 to 650 for a new 10 mil crank, and 75 to 125 plus shipping to have cases trenched...plus another hundo for the head to be cut. So...Probably a grand or so with the cylinders.
Then you get to worry about the tranny, clutch, swingarm, suspension, etc.
Unless you have the funds to commit to it, I'd let it pass. It is not a bolt on solution by ANY means...
Thanx for the input it looks like a huge bucket of worms to open. I will stay with mods I can do a little at a time and not break the bank.
Thanx
Jeff :starwars:
Easy...put a 10 mil spacer plate in, deck 5mil off the top. Sheesh...and I thought you were a smart guy....
:biggrin:
Taking 5mm off the deck wasn't mentioned and really isn't a good idea with OEM cases. :geek:
maybe 5mm of the cylinder deck is what he meant?
To me, the deck of the cylinders would be the ehad mating surface........... Doing that wouldn't do much other than raise your compression and your portiming would still be assed up. :geek:
I dont know what he meant. bottom of the cylinders?
Bottom of the cylinders would make sense.............. I was mostly just giving Dave a hard time. :biggrin:
Dave.. you really gotta keep up with technology.. everyone knows the flux capacitator is old school.. it was replaced with the oscilatin difibulation module . It save 4lbs and its Energy Star certified so it only need .6879 Jiga watts instead of the 1.21 your accustomed too..
Jesshh... Grab a magazine everynow and then would ya??
and "everyone knows I drink coffe when I watch radar!!"
LMFAO!!!!!
Is that some new fangled engine component engineer boy....?
:yelrotflmao: :yelrotflmao:
I've got a buddy that has some 68mm bb cylinders that have 5mm decked off the bottom. Builder says it has somethin to do with equalizing the crank pressure and this and that. :blink:
