freddy Posted May 1, 2008 Report Posted May 1, 2008 i got rid of my tors and remember reading that i had to connect some two wires together ??? am i good or wat else do i need to do??? my banshee wont stay idle? thanks in advance guys Quote
bunboy1 Posted May 1, 2008 Report Posted May 1, 2008 hi there, i just removed my tors as well. all you have to do is remove the tors box located next to the ignition coil, on the front left side under the fender. you do not need to connect any wires together. did you install the idle screw kit on your carbs? i have my stock carbs bored to 27.5mm and she idles fine, so i kinda wasted my money on that idle screw kit. i hope this helps. Quote
freddy Posted May 2, 2008 Author Report Posted May 2, 2008 hi there, i just removed my tors as well. all you have to do is remove the tors box located next to the ignition coil, on the front left side under the fender. you do not need to connect any wires together. did you install the idle screw kit on your carbs? i have my stock carbs bored to 27.5mm and she idles fine, so i kinda wasted my money on that idle screw kit. i hope this helps. oh ok well i did all that and she starts fine first kick, but i put some of my friends carbs on my bike and the same thing, so now i know its not my carbs, but im pretty sure its not the tors either, i take off and it boggs like crazy , do u guys know wat it might be, i thinks its flooded with gas from when my carbs were letting in too much gas into the reeds?? any input would be greatly appreciated Quote
omalavet Posted May 3, 2008 Report Posted May 3, 2008 hi there, i just removed my tors as well. all you have to do is remove the tors box located next to the ignition coil, on the front left side under the fender. you do not need to connect any wires together. did you install the idle screw kit on your carbs? i have my stock carbs bored to 27.5mm and she idles fine, so i kinda wasted my money on that idle screw kit. i hope this helps. hello but i bought a used banshee and it have the torts already removed and wen my shee gets wet it will accelerate it self!!!! and i saw two cables put together they were to black and yellow cables i wonder if those are the two cables you were talking about i remove those cables and the shee wont star put them back again and now problem i put some black tape around them so they will not contac water and accelerate i think the problem is solve but i wonder if i can remove that box ???? the box that you talk about is still there is a small black box that is in the front left size and is mounted under the tube of the upper chassis above the spark plugs??? can i remove that??? Quote
bunboy1 Posted May 6, 2008 Report Posted May 6, 2008 you dont need the tors box, so you can just remove it. as far as the bogging, how is jetting? try reading the jetting faq on this forum. it tell you what to do as for the jetting problems. Quote
dajogejr Posted May 6, 2008 Report Posted May 6, 2008 Unplug: The brain under the tank Both sets of wires going into the carb tops The parking brake/clutch lever wires going into the harness Cut the wires going into the stock throttle. You're done. Quote
