i just got new fmf gold series pipes,fattys,the header pipe on the rad pump side touches the rad hose, theres no way to make things fit, its the way it is. how come they designed it to touch, will it burn.should i stick a shim of somesort on between , the hose will move like 5 mil mimeteres but bounces back towards the pipe.any suggestions.
Hello, I've ran into this problem as well and used an old piece of rad. hose as a shim, hasn't burnt through that hose in over 2 years so it holds up. It probably transfers some heat to the coolant though, never thought about that. :blink:
