xXBlessedWithDeathXx Posted April 24, 2008 Report Posted April 24, 2008 (edited) I`m looking for a good set of boots for 2 - 35mm carbs. OEM cylinders. if the price is high dont let me know, that would just be a waist of your and my time :biggrin: . Edited April 24, 2008 by xXBlessedWithDeathXx Quote
jbooker82 Posted April 24, 2008 Report Posted April 24, 2008 You could get a White Knuckle Racing Intake or Boss Racing. It has a built in crossover tube. It also moves the carbs up and back so the LH Carb Bowl wont rub on the clutch arm. You can replace the rubber intake boots on them for about 20 bucks too. They use the standard Mikuni Carb Flanges. I run a boss on my banshee with 33PWK's. It fits good. Probably a little more than what you wanted to spend but they are deffinatly worth it when trying to stuff bigger carbs between the frame rails. White Knuckle Racing LINK Quote
xXBlessedWithDeathXx Posted April 25, 2008 Author Report Posted April 25, 2008 I got a set off ebay for $87 but the one you posted looks sweet. Quote
