ok i finally got my shee toghether . it wont start . it sounds like it wants to but nothing . the pipes get hot but nothing. i dragged it down the road but it try to start but as soon as you stopped pulling same thing. after i pulled it i tried kicking and it sounded really good but still nothing. any help guys. i have a 2 into 1 carb toomey pipes. entire motor was rebuilt by me. i have compression and spark every time i pull the plugs they look dry but every couple of kicks i get some flame out the header (silencers are off)
Did you put the pistons in the right way.
ha ha no no rags. i took the bolt off and gas came out so im not sure ha ha. i have a ride to go on this weekend and there all gonna b 2strokes dont wanna go with a thumper :banghead:
did u put the little cross over tube between the carbs???
timing set?
plugs sparking?
plugs installed?
2 into 1 carb no crosssover tube
flywheel is good
plugs sparking
is the kill switch in the STOP position?( this may sound stupid but i've seen it done alot)
\i was thinking that because my kill switch is really old and it doesnt click over to run or off it slides over with ease was wondering if the actual switch may be broken . does the bike get spark when its switched to off? . if i disconnect should it work or do i need it hooked up?
and bunboy good luck i will damn sure not take my bike to a local shop ha ha
Edited by 89shee
