ItzaBansheeBitch Posted April 12, 2008 Report Posted April 12, 2008 Taking my new banshee to the strip in a few weeks, What teeth do yall run for the 1/4 mile? Will be racing 600cc street bikes. Quote
badassbanshee479 Posted April 12, 2008 Report Posted April 12, 2008 if it will pull it, run 18-39 should get ya the whole length of the track. Quote
docjcwatson Posted April 12, 2008 Report Posted April 12, 2008 if it will pull it, run 18-39 should get ya the whole length of the track. Yup! That's what I will be runnning this year on my 1/8th mile alky 14mil. 18-38 might work too. - Justin Quote
banshee332 Posted April 12, 2008 Report Posted April 12, 2008 if it will pull it, run 18-39 should get ya the whole length of the track. I dont think 18-39 is going to cut it. I run 17-36 with 2:68 pri's with 22" tires in 500ft. I think hes going to need to try and pull more gearing hes going to be toped out right around the 1/8th mile marker. It also depends on what kind of motor he has, compression and etc Quote
SlowerThanYou Posted April 13, 2008 Report Posted April 13, 2008 I dont think 18-39 is going to cut it. I run 17-36 with 2:68 pri's with 22" tires in 500ft. I think hes going to need to try and pull more gearing hes going to be toped out right around the 1/8th mile marker. It also depends on what kind of motor he has, compression and etc 18/39 should be pretty close depending on numerous factors, better have the motor to pull that gear. We have run 10.80 @ 115 mph with that ratio with 2.86 pri's and 20" tall tires. Bryan Quote
