I know there have been a lot of posts lately on the compression/cool head topic and I did use the search button multiple times but I didn't find anything that really answered my question. I don't know a whole lot about this stuff so please bear with me. I am looking to get a cool head and I want to know if I can run +4 timing with 21cc domes on pump gas. If so is 21cc the smallest I can go (with +4 timing) and still run pump gas without detonation? My compression right now is at about 125psi at 800ft above sea level. Thanks.
I ran mine on 93 @32 above sea level 21cc domes and +5 timing and 150-157psi just fine, but that is about the safest limit.
the only way your going to know 100% if you can run it or not is to do a compression test with the domes in, there are so many factors you can not rely on what others have done, they can only get you a ballpark idea.
^^^^^^word
Yeah I knew I would have to test the compression once the domes were in but I just wasn't sure if having a higher compression (just say 150psi) and +4 timing was still safe on pump gas. Would my best bet be to try it and if I get detonation to back the timing off a little or won't the higher compression affect my ability to advance the timing?
Edited by Banshee96
