here it is im running pro circuits with v force 3s and a k
&n in the box stock carbs i have 27.5 pilots and 300 mains if i switch to toomey t5s do you think il need to go up a size on the mains also im sea level to 1000 feet tops
I ran 280 main and 25 pilots with toomey needles on the middle with my stock carbs, it was perfect.
most people have their banshees jetted way too rich to begin with i think, i just think that what toomey recommend with their pipes, is alot closer to accurate than what most people are used to running, i always hear people say "my plugs are a perfect chocolate brown color".. they should be nowhere near chocolate brown if that helps at all, its up to you to play with it though, so many factors like airbox setup and filter come into play, i found on mine with t5's, vf3's and a k&n in the box with 8x4" hole cut through both layers of the top it runs best in the warmer weather with 280 mains, stock pilots and toomey needles on the 3rd clip down,(their recommendation of 4th clip is just too dam rich for me) and from 1.5-2 turns out on the air/fuel screws, i ride sea level to about 1000 ft in the warm weather, every bike is gona be different though
ya my plugs are usually tan at best i usualy go by how it runs and if it blows up its just an excuse to add more better parts i was just lookibg for you guys opinions but it doesnt matter any mor because the t5s i was guna buy got stolen out of my buddys garage along with a lot of other stuff the night before i was suposed to go get them. man that pisses me off but thanks any ways
