Don't worry about it...
See the purple line going into the fitting on the left side, in front of the reeds....
That's a vacuum pulse line, same thing we all do, I just put mine on the other side.
Normally you mount a pulse pump under the seat nose...
I used 1/4" flat steel, bent it as needed to make the pipes line up and drilled two holes in each brace, and used two rubber grommets on each bolt for cushion.
If you look at the inside of the pipes you can see the little brackets
what pipes are these ,travis ??
