banshee_guy_05 Posted March 19, 2008 Report Posted March 19, 2008 Hey all. i just got a new set of fmf gnarly pipes for my banshee and they rub the radiator hose coming out of the water pump. i have it routed and zip tied out of the way from everything else but it just barely sits on the pipe just where it come out of the pump. Anyone else have this problem? Does it get hot enough to burn throught the hose? Any quick and easy fixes? I have seen most aftermarket radiator hose sets are around 80-90 bucks and i hate to spend that kind of money on something i dont really need. Thanks alot! Quote
tnr Posted March 20, 2008 Report Posted March 20, 2008 (edited) Your stock radiator hose is formed in a certain shape. All you have to do is loosen the clamps and turn the hose around until you get the best fit. Make sure you do both clamps on the particular hose so you wont get any kinks. Edited March 20, 2008 by tnr Quote
dajogejr Posted March 20, 2008 Report Posted March 20, 2008 Swap the lower hose... I've had to do this with T5s and other aftermarket pipes. All you do is pop off both ends and the end that goes to the radiator, hook it to the waterpump and vice versa...and twist the hose if need be. Should be fine. Quote
banshee_guy_05 Posted March 21, 2008 Author Report Posted March 21, 2008 Ill give it a try in the morning and ill let you know how it works! Thanks! Swap the lower hose...I've had to do this with T5s and other aftermarket pipes. All you do is pop off both ends and the end that goes to the radiator, hook it to the waterpump and vice versa...and twist the hose if need be. Should be fine. Quote
