REmove the cable itself from front to rear. Now would be a good time to remove TORS if you haven't done so.
Thats it? & just put on block off plate? Damn thats too easy! & Yes the tors is coming off too! Thanks
Are you takling about the shift cam?
yes make sure you undo the plug at your P-Brake. there is a small botton behind it thats runs the TORS> make sure you unplug it. its just remove the two bolts on the rear caliper and pop it out. put the plate one and bolt it down
