shovelhead Posted March 16, 2008 Report Posted March 16, 2008 Ok I got a block-off plate , so can someone tell me what I need to do to remove the parking brake system? I have no instructions..Thanks Quote
ClimbAnyHill Posted March 16, 2008 Report Posted March 16, 2008 REmove the cable itself from front to rear. Now would be a good time to remove TORS if you haven't done so. Quote
shovelhead Posted March 16, 2008 Author Report Posted March 16, 2008 REmove the cable itself from front to rear. Now would be a good time to remove TORS if you haven't done so. Thats it? & just put on block off plate? Damn thats too easy! & Yes the tors is coming off too! Thanks Quote
Bansh-eman Posted March 17, 2008 Report Posted March 17, 2008 Are you takling about the shift cam? yes make sure you undo the plug at your P-Brake. there is a small botton behind it thats runs the TORS> make sure you unplug it. its just remove the two bolts on the rear caliper and pop it out. put the plate one and bolt it down Quote
Animalman294 Posted March 17, 2008 Report Posted March 17, 2008 I then took an angle grinder to the part on the handle bars to clean it up a little............ Quote
