I went riding today and all of the sudden while under half throttle the shee seemed to lose alot of power.. I noticed the rubber gasket between the motor and exhaust pipe has broken and there was a leak.. I replaced the rubber gasket but still no power.. I noticed that when i put my hand up to the pipes the left cylinder didnt have nearly the exhaust pulse as the right cylinder..
What could b wrong????
mods are
wiseco top end
v force 3 reeds
toomey t5
jetted
k&n filter
thanks
there is 3 thing an engine needs in order to run. Fuel, compression and spark. I'd start off with new plugs. If that does nothing than run a compression test. If that is good (no variance above 10%) than check your fuel system out.
4 air :thumbsup:
