FeLiX Posted March 10, 2008 Report Posted March 10, 2008 see i had it in storage for about a year got it out and we couldnt get it to start, got it to start for a sec after pull starting it, then tried to kick start it again and the kicker got stuck but then released and i havent had it running since! any thoughts? Quote
magz Posted March 10, 2008 Report Posted March 10, 2008 see i had it in storage for about a year got it out and we couldnt get it to start, got it to start for a sec after pull starting it, then tried to kick start it again and the kicker got stuck but then released and i havent had it running since! any thoughts? when you pulled it out of storage did you.....put fresh gas with fresh pre-mix in it, did you clean the carbs out, did you drain the carbs before you put it in storage? cause if you didnt there probably clogged up. might want to change the tranny oil while your at it., check for spark, then go from there. Quote
FeLiX Posted March 10, 2008 Author Report Posted March 10, 2008 when you pulled it out of storage did you.....put fresh gas with fresh pre-mix in it, did you clean the carbs out, did you drain the carbs before you put it in storage? cause if you didnt there probably clogged up. might want to change the tranny oil while your at it., check for spark, then go from there. i changed the gas and mix cleaned the carbs because i had to rejet for the season but i didnt drain them before i put it in storage was in a hurry to move out of the x-old ladies lol! but there is spark and the compression seems right im gonna buy a compression tester later this week but any other help too would be great thanks Felix! Quote
