f4istunna Posted March 10, 2008 Author Report Posted March 10, 2008 what you asking for complete bottom end? 01 motor bottom end, need lower rod bearings Good tranny, goes through gears, good clutch side covers, kicker included, Left case has the normal banshee chunk missing from chain smacking it, but its just on the lip nowhere where it would cause leaking problems or anything other than cosmetic. $250 Cool head w/ cylinders and reeds (ebay) ??year bottom end Crank bearings seized, has clutch, good tranny, kicker, sidecovers etc complete. No case damage. $250 *** SOLD Cylinders no gouges or deep scratches pretty sure stock bore $150 SOLD Stock head $25 one dome has some buildup needs cleaned. SOLD Stock carbs $20 stock carbs complete $35 Radiator w/ hoses, cap $50 ebay Dg full pipes $75 ***SOLD Reeds w/ cage $15 ***SOLD Electrical Complete Wire harness w/ components coil, cdi etc $30 ***SOLD Headlight switch $20 Ignition switch w/ key $15 Headlights $25 (pair) -- Frame $200 painted lime green, all threads are good, looks to be straight, no cracks or damage that i noticed. Bill of sale -- chrome Front bumper ? not sure brand? $20 ***SOLD -- chrome Grab bar ebay -- Black/blue seat w/ pan, foam, cover, latch gripper material center blue sides $35 ebay --Rear wheel hubs (pair) $25 --Thumb throttle w/ cables $20 -- Stock axle $40 ***SOLD -- Steering stem $40 ebay --spindles (pair) $30 ***SOLD -- stock footpegs (pair) $5 -- Rear brake hub w/ rotor $20 -- Front wheel hubs w/ rotors $40 -- Rear brake master cylinder w/ lever and resi$25 -- Rear brake caliper w/ lines $30 --Front brake calipers w/ lines hard and rubber $40 -- Front master w/ lever $20 --Front oem wheels straight, normal trail scuffs and nicks on lips $55 (pair) --Front ITP wheels (thick aluminum) some nicks on lips, hold air and straight $70 or with 50-60% maxxis razr 21" $85 --Rear oem wheels normal trail wear on lips $65 --stock front shocks $15 -- Rear shock $25 --clutch lever perch and cable $15 --Plastics Blue race cut fronts, stock rears, no cracks w/ tank cover and rad cover $80 --Rear sprocket 41t w/ hub $10 --Gas tank w/ cap and petcock $25 --Swingarm w/ carrier (good bearings) $55 --Rear shock linkages $10 --A arms good balljoints on all right lower has dent, still looks to be straight but pretty good dent on bottom $45 for all 4 --tie rods w/ ends $20 Quote
88_trex Posted March 10, 2008 Report Posted March 10, 2008 01 motor bottom end, need lower rod bearings Good tranny, goes through gears, good clutch side covers, kicker included, Left case has the normal banshee chunk missing from chain smacking it, but its just on the lip nowhere where it would cause leaking problems or anything other than cosmetic. $250 could you send me some pics? Quote
f4istunna Posted March 11, 2008 Author Report Posted March 11, 2008 could you send me some pics? ya shoot me your email i have a few pics of the motor. One rod bearing has a good amount of up and down play, the other is good (not that it matters lol) just wanted to give you the details Rear wheel hubs sold Quote
88_trex Posted March 11, 2008 Report Posted March 11, 2008 could you send me some pics? ya shoot me your email i have a few pics of the motor. One rod bearing has a good amount of up and down play, the other is good (not that it matters lol) just wanted to give you the details Rear wheel hubs sold my e mail is [email protected] Quote
f4istunna Posted March 11, 2008 Author Report Posted March 11, 2008 pics sent let me know thanks Quote
DUALSTROKE Posted March 12, 2008 Report Posted March 12, 2008 Sent you a p.m. on rear brake caliper with line,rez,master cyl,etc.Let me know.Thanks Quote
f4istunna Posted March 12, 2008 Author Report Posted March 12, 2008 pm replied, i have another guy who asked first (yesterday) if he doenst take it in the next day or so ill let you know Thanks Quote
f4istunna Posted March 17, 2008 Author Report Posted March 17, 2008 made an updated list of what i have left Quite a bit sold already I accept paypal and MO, and will ship by next business day after payment received. Still have -- Complete bottom end one fo the lower rod bearings shot (crank) no leaks, does have the usual shain damage to the outter edge of case but no where where it would cause problems. Comes w/ clutch, tranny etc (all internals) side covers etc. $250 -- 01 frame, straight good threads didnt notice any cracks bends or previous repairs, painted green $200 comes w/ original bill of sale -- Front calipers with lines $30 --Front brake master cyl. with lever $20 --Set of 4 a arms (lower right has a pretty good dent, looks to be straight from what i can tell) $40 all 4 or $15 a peice sep. balljoints feel good --Tie rods w/ ends $20 --Swingarm w/ carrier (was no play in bearings, and rolled good) $50 --Front shocks Springs chipped up $20 --Rear adjustable shock $25 works good looks decent --Engine mounts/bars $5 --Rear sprocket hub $5 --Oem carbs complete $25 --Headlight/kill switch assembly $20 --Thumb throttle w/ cables $20 --Headlights $15 pair, were painted i cleaned them up could use lens polished (kinda dull) --Swingarm pivot bolt $10 --One peice 7/8th handebars black not sure brand $5 --Oem clutch lever and perch $5 --Ignition switch w/ key $10 --Open intake w/ uni filter (looks like stock airbox cut away ??) $10 --Plastics Blue , fronts cut rear full w/ radiator and handlebar peice $80 I have pics of most of this, if you dont see it on the first cpl pages shoot me your email and ill get them to you if wanted Thanks Quote
alt0705 Posted March 19, 2008 Report Posted March 19, 2008 I'm looking for stock or aftermarket headlights for my 'shee. Located in N.E. Ohio as well (Ashtabula). [email protected] Quote
f4istunna Posted March 20, 2008 Author Report Posted March 20, 2008 I'm looking for stock or aftermarket headlights for my 'shee. Located in N.E. Ohio as well (Ashtabula). [email protected] I have a set you can have for $10 $15 or so the lens need cleaned up Quote
f4istunna Posted March 20, 2008 Author Report Posted March 20, 2008 taking offers looking to make some room all the leftovers must go. Quote
f4istunna Posted March 23, 2008 Author Report Posted March 23, 2008 anyone else?? im going to throw the rest on ebay this week Let me know if you guys can use anything thanks Quote
gumby6t9 Posted March 23, 2008 Report Posted March 23, 2008 will you sell me the front race cut fenders? I don't need the other plastics. Let me know! Quote
