FREAKSHOW Posted February 28, 2008 Report Posted February 28, 2008 OK, Parked the 250r and Just got my first banshee, 2001, 4mil storker kit, bored .050 with modquad intake, v-force and 28pwk's on it. The left cylinder is spiiting fuel out the exhaust and i mean alot!!! It does this until the engine rpm gets to the top of the power band. The engine is real unresponsive then all of a sudden comes alive.( I know 2 strokes are supposed to do that but this is bad). the compression seems good, I removed the left carb disassembled and checked everthing and it appears in good shape. put back on and same problem. The carbs are syncronised. the jetts are both 155. It seems that the carb is flooding that cylinder. Any idea's ? OH yea, will stock carbs feed this engine or should I stay with pwk's ? Thank you verry much!! Quote
fastbanshee8 Posted February 28, 2008 Report Posted February 28, 2008 Incorrect float level, bad plug boot, flywheel pickup gap incorrect???? Once you find, and correct the problem, it would be a good idea to repack the silencers, because the packing in the left side is probably swimming in fuel/oil. Quote
