we's banshee Posted February 24, 2008 Report Posted February 24, 2008 so guys can someone please tell me which is the best rear sprocket for my banshee aluminum or steel :confused:thanks Quote
Bansh-eman Posted February 24, 2008 Report Posted February 24, 2008 stick with steel, the aluminum sproket fall apart much faster then steels. I ripped the teeth off a few aluminums before I swapped to steels. Now not only do Ispend less on steels but I havent replaced one yet from breaking Quote
we's banshee Posted February 24, 2008 Author Report Posted February 24, 2008 so guys can someone please tell me which is the best rear sprocket for my banshee aluminum or steel :confused:thanks thanks for the info.that's what i thought too but i just had a few people trying to convince be aluminum was better Quote
we's banshee Posted February 24, 2008 Author Report Posted February 24, 2008 thanks for the info.that's what i thought too but i just had a few people trying to convince be aluminum was better so what name brand would you guys run Quote
Bansh-eman Posted February 24, 2008 Report Posted February 24, 2008 any steel sproket is fine. call FAST he has good prices Quote
jbooker82 Posted February 25, 2008 Report Posted February 25, 2008 Aluminum only really should be used on a Motorcycle. The only advantage of aluminum is they weigh less. So on a motor cycle that has a rear sprocket the size of a pizza pan they are worth it. On atvs they are smaller so weight savings is minimal. josh Quote
we's banshee Posted February 25, 2008 Author Report Posted February 25, 2008 Aluminum only really should be used on a Motorcycle. The only advantage of aluminum is they weigh less. So on a motor cycle that has a rear sprocket the size of a pizza pan they are worth it. On atvs they are smaller so weight savings is minimal. josh thanks for all the help.i just couldn't make my mind up as to which way i needed to go with it. Quote
dajogejr Posted February 25, 2008 Report Posted February 25, 2008 Depends on what you're doing... I run an aluminium rear...a few hundred passes on the drag strip, 110 to 115 HP cub motor...it still looks great. What kind of riding do you plan on doing? If you're going to run mud/trails, etc. Get steel... If you're gonna drag race and ride the dunes, get aluminum...they work just fine. Steel is heavier but cheaper.... Keep in mind, with a crappy, mis adjusted or worn our chain, ANY sprockets won't last long.... Quote
shanYE west Posted February 25, 2008 Report Posted February 25, 2008 (edited) I got 3 seasons on my alumium sprocket with over 70hp the first 2 and 100+ the 3rd season. Like anything else maintaince is the key to longevity. Edited February 25, 2008 by Fouledout421 Quote
we's banshee Posted February 26, 2008 Author Report Posted February 26, 2008 I got 3 seasons on my alumium sprocket with over 70hp the first 2 and 100+ the 3rd season. Like anything else maintaince is the key to longevity. thanks for all the help.i really it!i have had all kinds of people telling me different things.i do ride in mud,sand,snow(when we get some) and i really needed something to hold up.thanks again Quote
dajogejr Posted February 26, 2008 Report Posted February 26, 2008 In your case..then, I'd recommend steel and a good X or O ring chain as well... Good luck!! Call Jeff @ FAST. He carries bulk chain by the foot and I"m sure he can get you a great deal on what you need. Quote
