ridin420 Posted February 23, 2008 Report Posted February 23, 2008 hey got a 04 runs good other than a bog a low rpm in evry gear any sugestions got toomy t6 290 main stock pilot k&n it is like -4 outside at sea level oh ya 1 turn out on thee air screw any help would be awsome Quote
magz Posted February 23, 2008 Report Posted February 23, 2008 hey got a 04 runs good other than a bog a low rpm in evry gear any sugestions got toomy t6 290 main stock pilot k&n it is like -4 outside at sea level oh ya 1 turn out on thee air screw any help would be awsome follow the chart, might do 1 more turn on air screw, and see if that helps, if it doesnt try moving the clip position. but just do 1 adjustment at a time. being that cold out i might try 310 mains too since the motor will be getting a ton of air sounds a little lean. Quote
mason07shee Posted February 24, 2008 Report Posted February 24, 2008 follow the chart, might do 1 more turn on air screw, and see if that helps, if it doesnt try moving the clip position. but just do 1 adjustment at a time. being that cold out i might try 310 mains too since the motor will be getting a ton of air sounds a little lean. I jusrt fixed my shee today same problem put in a 30 pilot 1.5 turns out and thats it man works awsome Quote
