KaosBanshee44 Posted May 26, 2008 Report Posted May 26, 2008 the #425 emery impregnated discs worked well for me. especially on the rough parts and on the hubs. Those looked like cutting disc, i bought a little polishing kit from sears and it had those disc in it. I was wondering why they put cutting disc in a polishing kit. Quote
Wildcardracing Posted May 26, 2008 Report Posted May 26, 2008 I did my top case only, what a PITA!!! I found I had the best results using #400 wet/dry sand paper on the larger areas by hand to get all of the rough casting marks smoothed out. Then I used the dremel sanding buffs to do the tight areas. Once it was all smoothed in I used #500 and then #600 sandpaper to get the deeper scratches out. Then I used liquid polish (mothers) to get them shinny and finished up with never dull to make it look like chrome. I didn't bother with the lower case or counter sprocket area because they are both so hidden I didn't think it would matter much. Plan on spending about 10 hrs polishing on the top case alone. Quote
tnGRbanshee Posted May 30, 2008 Report Posted May 30, 2008 do them yourself its not rocket science but takes alot and i mean alot of time .i did alot of polishing on all kinds of dif. parts but no amount of money could get me to do somebody elses . but really its all worth it when your done ,a good sense of accomplishment. Quote
KaosBanshee44 Posted May 30, 2008 Report Posted May 30, 2008 do them yourself its not rocket science but takes alot and i mean alot of time .i did alot of polishing on all kinds of dif. parts but no amount of money could get me to do somebody elses . but really its all worth it when your done ,a good sense of accomplishment. It is i'm already done check the images section titled "To Kiel (theshee)" I posted a pic there. Quote
