ok guys, so i finally get a chance to ride my passion stroker. first of all the bike ripps....i got about 40 minutes into my ride when i starting stalling when coming to a stop. i checked the clutch cable adjustment and it wasnt moving the clutch arm as much as it should. so i adjusted my lever enough to pull some more slack to get home and about 2 minutes before i got home i had no clutch what so ever. i kept it in 2nd gear and got home.
now that i am off the bike, i pull the clutch lever in and watch the arm and it moves all the way it should but there is no tension on the lever what so ever. i am guessing this has to be internal...which sucks because i just got the bike back. any ideas on where to start?
yep, had a buddy that this happened to, take the clutch cover off, on the pressure plate, in the center will be an adjuster with a locknut, i would bet money that the locknut nas backed off and the adjuster has vibrated loose.. you will probably find the locknut chewed up somewhere..
sounds like you welded the ball and rod. better get your mechanic jon to work on it. and get the pancake bearing to me.
yea we talked already. he seems to think its the same thing. i will start taking it out tomorrow after work.
the clutch locking washer broke, caused the nut to losen. the whole clutch basket assembly shifted over and threw the clutch out of alignment. so it was a 3 dollar washer. not the ball/rod. i will be adding the pancake bearing and a shift pro mod while im in there.
Umm... there's no lock washer in the clutch. Sounds like someone ghetto-rigged your shit. ROFL
now the kids asking for help. because he don`t know. and you are laughing at him and talking shit?
what a fuckin asshole.red you are a fuckin knucklehead. i thought that even before you gagged me for that go ped pipe.make more stupid ass replies like that in peoples threads.
